Ir para o conteúdo principal
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 Perguntas Visualizar todos
Ipad 4 repair question.
I want to repair an ipad 4 lte, but I want to make sure I get the right part. I've tried re-booting it and these grey lines still persist, and the touch screen still works, so I need a new lcd screen, right?
Thanks for any help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Is this the only thing you see on the LCD? Logically speaking it should be just the LCD that is defective. However, if the iPad has been dropped a lot, had a recent repair or came into contact with water, it might be a bad connection or logic board related.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Yeah, it's only grey lines that show up, also I'm not sure if any of those things've happened to it.
por
Then the logical thing to try first is a new LCD.
por
Okay, thanks.
por
Adicionar a sua resposta
S Pin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 60
