Ir para o conteúdo principal
O Verizon Ellipsis 8 é um tablet que possui uma tela HD, bateria de 5000 mAh e capacidades 4G LTE.
keeps rebooting ,optimizing app 135
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi,
It may be that a downloaded app is causing the problem.
Try starting the tablet in safe mode to check that it starts up OK without rebooting.
If it does then a downloaded app is the problem. The trick is to find out which one.
If you have just recently installed or updated some downloaded apps and then the problem started try uninstalling them first, one by one. Check between each uninstall if the problem has gone by trying to start the tablet in the normal way and see if the problem has gone. If it has then the last app uninstalled was the problem
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
gus pappas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 999
