What does the spanner symbol mean next to the power button
My wl70t60d machine turns on but won't work. When I stopped it beeped about 10 times and then the spanner lit up next to the power button. What's wrong?
Esta é uma boa pergunta?
@jaffa2018 the spanner icon is the service light. According to the manual try this:
The service light (spanner icon) is flashing.
1. Turn your machine off at the wall.
2. Wait 1 minute and turn it back on.
3. Check your machine is level (refer to installation instructions pages 2 – 4).
4. Remove load and retry.
5. Put through a RINSE and SPIN cycle.
6. If the fault re-occurs repeat steps 1 and 2.
Let us know what happens when you do so.
Esta resposta foi útil?
Hi @Alan Smith
Not sure if this is applicable to your particular model, but try entering the diagnostic mode for your type (mode 2?) to see if you can view the last error code stored in the washer.
I realize that the manual linked is not for your particular model (can't find one for your model) but it is for a F&P Aquasmart WL series washer, so hopefully it is the same procedure. If it works the fault code meanings are shown listed from p.45 onwards.
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 53
Ao todo: 12,474
1 comentário
Nothing it won’t start
por Alan Smith
