Ir para o conteúdo principal
Caixa de som portátil JBL Flip 4. Caixa de som Bluetooth com dois alto-falantes eletrodinâmicos e classificação à prova d'água IPX7, vencedora do prêmio CES Innovation Award de 2017.
Not charging or turning on
My JBL speaker has been working fine and now nothing lights up even when it’s plugged in. I’ve used 3 diffrent cables to try and charge it with they don’t make a difference. Nothing has worked and it makes me sad. I’ve tried resetting it and again nothing happened, so I don’t know what to do.
Esta é uma boa pergunta?
Pontuação 2
4 comentários
i fixed it,
you have to put
pressure on the flat cable that is connected with the "power button/LED/ JBL Connect Chip". Then you have to put a cable back in the usb chip
after that it should work again
por
And how do you do that?
por
all of you are wrong!!!,
Did you check the 5v on the usb type v8 line?
Did you check the 5v on the usb board?
Did you check the 5v get to IC charging?
Did you check the 5v get to Batery?
Did you check the 3.3v & 2.7v & 1.2v to the PMIC?
por
how do i check all these? is there a kind of tutorial?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
If your JBL Flip 4 speaker refuses to turn on, see the JBL Flip 4 Won’t Turn On problem page for possible causes and solutions.
If your JBL Flip 4 speaker will not charge or won’t hold a charge, see the JBL Flip 4 Will Not Charge Or Won’t Hold a Charge problem page for possible causes and solutions.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Abigail J Rhea será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Ao todo: 3,770
