Does your JBL Flip 4 no longer hold a charge for as long as it used to? Does it not charge at all? JBL Flip 4 speakers are susceptible to a range of problems that could cause them to stop charging or lose charge quickly. Check the following possible causes to identify and solve the problem.
Faulty Battery
If your JBL Flip 4’s battery is not charging or unexpectedly turns off, it may have a faulty battery. Before replacing the speaker’s battery, check to make sure that the speaker has not been left in abnormal temperatures, such as near a stove or fireplace. Abnormal temperatures can cause the device to lose battery power more quickly than normal. If the battery issues continue, use the JBL Flip 4 Battery Replacement Guide to replace the speaker’s faulty battery.
Faulty Charging Port
If your JBL Flip 4 still refuses to charge after replacing the battery, it may have a faulty charging port. To replace the speaker’s charging port, use the JBL Flip 4 USB Port Replacement Guide.
Questions other people have asked about this
- Flip 4's battery runs out quickly and other problems.
- My JBL Flip 4 doesn't turn on and charge.
- JBL Flip 4 is not charging
- Not charging or turning on
- JBL wont't turn on and takes no charge after failed to update firmware
0 comentários
