Ir para o conteúdo principal
Lenovo IBM Laptop screen is blank
Why Lenovo IBM Laptop is on but the screen isn't working to display boot process?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
@avrickabel possibly a bad LCD or bad GPU. Connect an external monitor and if that works you will know that your LCD needs to be replaced. Now, word of caution. This series had two types of backlight. One being LED and the other CCFL. The CCFL version may have an inverter. Shine a flashlight at an angle against the screen with the computer on. If you can make out silhouettes of the screen etc.,then you know it is your backlight. You'd have to disassemble your computer and post some images of what you see with your question. That will allow us to help you further. Use this guide Adicionar imagens a uma pergunta já existente for that. This guide will help you with your repair Lenovo ThinkPad T500 Screen Replacement
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Lenovo ThinkPad T500 Screen
Guia
Moderada
15 - 20 minutes
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Abel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 955
