Ir para o conteúdo principal
Um conversor de baixo custo da Access HD que permite que TVs analógicas e TVs “digital ready” recebam sinais de televisão digital UHF e VHF via antena.
Coverter box not working at all
Hi,my name's Myra
I have a dta1030 coverter box,nd my question is,can i reset my coverter box?
Because certain channels blackout,
I cant get channels 29 fox,nd get tv channel 63 is now on 28 nd that doesn't play at all nd neither does all of channels 2 or 35.
Can i get some help?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi,
Have you tried just rescanning for all the available channels again?
Are the channels that you mentioned, not being detected at all, or are they being deemed as too low a signal level to be accepted by the converter when it scans for the channels?
Also just checking that the channels are not showing up as 'not viewable' in the converter's Channel List Editing menu
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Move your antenna to a different location, or point it in a different direction. It may be that the missing channels simply don't have a strong enough signal for your box to receive them.
If moving the antenna solves the problem, then you might want to get a better antenna, so that it can pick up all of the channels without having to move the antenna.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
marrah41 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 528
