Ir para o conteúdo principal
Guias de reparo e assistência para periféricos de jogos, como joysticks, volantes de corrida e controles de terceiros.
Cord disconnected from circuit board
So I was playing and I forgot I was still holding my controller and went to p1ss so that yanked off the cord from the circuit board. Years later I tried to reconnect it using a cord that I found, (not for controllers but had 4 smaller wires) and soldered it to the circuit board. Doesn't work. What do?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @densetsu ,
What is the make and model number of the controller?
Can you also post another picture as the one that is there is a bit out of focus, when it is enlarged for a better view, making it difficult to see the cord connection terminals properly to see if there is anything written on the pcb?
What type of plug is connected at the other end of the cord and how did you wire that or is it the original and you spliced in the new cord?
por
Idk the model number, its generic and I bought it for $9. I cut off the smaller plug (from a cord for charging a portable electric fan I think) at the end exposing 4 smaller wires and connected them randomly.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @densetsu
OK well looking at the pictures we may be able to work something out.
On the image below I've drawn two arrows which I believe are connected together by the track between them.
If this is correct follow that track back to the cable connectors to find out which terminal it connects to.
I'm guessing that it will be one of the outside ones of the four. (looking at them in the picture from Left to Right number them 1 2 3 4 ). So it will either be 1 or 4.
If this is correct then connect the RED wire to either 1 or 4 depending where the track goes. Then connect the BLACK wire to either 1 or 4 depending on where the red wire is. (So it is either red on 1 and black on 4 OR red on 4 and black on 1)
The GREEN and WHITE wires will connect to 2 and 3. If it doesn't work, reverse the green and white wires, i.e. if green was on 2 then put it on 3 and take the white wire off 3 and put it on 2.
Hopefully this makes sense and also that you haven't already damaged any components by placing the power leads on the wrong terminals.
(click on image to enlarge for better viewing)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jason Rodriguez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 240
