Ir para o conteúdo principal
O LeapFrog LeapTV é um console de jogo lançado em 2014. O LeapTV permite que as crianças brinquem gastando energia. O console permite que as crianças completem tarefas pulando, dançando e realizando outros movimentos físicos.
Looking for Ac Adapter
I’ve been looking for a replacement ac adapter online for hours. I can’t find any that are specific to the LeapTV system. Could you please point me in the right direction?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Did you find one that works? I just purchased one from fb marketplace and it doesn't have the power cord, so essentially useless at the moment
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Hi @radiatehope ,
Here is a link to one supplier.
It is not a recommendation to use them. It is shown to give an idea of the price. There are others online, especially on Ebay. Just search Ebay for LeapFrog Leap TV adapter to get results.
Alternatively these are the specifications for the adapter.
AC Adapter Electrical Ratings:
US, CAN Input: ~ 120VAC, 60Hz
UK Input: ~ 230VAC, 50Hz
Australia and New Zealand Input: ~ 240VAC, 50Hz
Output: DC9V, 700mA, 6.3VA
Depending on your location if you search for a 9VDC 700mA adapter you should get results. If there are none then a 9VDC 1000mA adapter will be fine.
The thing to be careful of is the size of the DC plug that comes with it. I cannot find out the size (I assume it is a barrel type DC plug and they come in different sizes). There are adapters available that come with multiple interchangeable plugs, so hopefully one of them should fit.
Esta resposta foi útil?
Pontuação 3
1 comentário:
@jayeff , thank you!
por Compartilhar
The DC plug is Center positive
Imagem
Pontuação 0
Adicionar a sua resposta
Christina será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 41
Ao todo: 1,185
