flashing folder ? need new HD
How do I tel which one or can I just install the fastest available?
serial # YD81437MZ64. Thanks, Mike
Esta é uma boa pergunta?
Any of the ones listed here under the device page on iFixit will work.
Esta resposta foi útil?
You need to have it fit the enclosure... 2.5X up to 9.5mm thick. Some like 72KRPM drives they're a bit faster, but also more expensive.
Good Luck,
N.
You might not need a new drive, hold "Option" when booting, and this will bring up a boot menu, and the choice to select a startup disk, so you may be able to select your hard drive, and tell it to boot from that.
Sounds like he already tried.
I have just installed a new HDD in one of these for a friend of mine.
A 500GB Western Digital I bought from ebuyer.com for £60.00.
But try what Chris Green suggests just in case you don't need one.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 886
