Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Perguntas Visualizar todos
Pergunta encerrada
flashing folder ? need new HD
How do I tel which one or can I just install the fastest available?
serial # YD81437MZ64. Thanks, Mike
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
Any of the ones listed here under the device page on iFixit will work.
Esta resposta foi útil?
Pontuação 1
You need to have it fit the enclosure... 2.5X up to 9.5mm thick. Some like 72KRPM drives they're a bit faster, but also more expensive.
Good Luck,
N.
Pontuação 0
You might not need a new drive, hold "Option" when booting, and this will bring up a boot menu, and the choice to select a startup disk, so you may be able to select your hard drive, and tell it to boot from that.
Pontuação 0
1 comentário:
Sounds like he already tried.
por
I have just installed a new HDD in one of these for a friend of mine.
A 500GB Western Digital I bought from ebuyer.com for £60.00.
But try what Chris Green suggests just in case you don't need one.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 886
