Ir para o conteúdo principal
A máquina de costura Singer EZ-Stitch Chainstitch foi projetada para ajudar iniciantes a criar seus próprios projetos divertidos e criativos. Ela pode ser usada para montar artesanatos, roupas, almofadas, acessórios e muito mais.
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Its not the machine pictured. I have a full size machine.
por Compartilhar
@magecat any idea what model your machine is?
por Compartilhar
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
ladycerridwyn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 1,767
