Ir para o conteúdo principal
phone stuck in recovery Mode
Good evening please I have an iphone 6 that does not turn on since yesterday; it is stuck in recovery mode. When I try to flash it with 3Utool it says "INVALID SERIEAL NUMBER" and with itunes it shows the 3600 error.
I tried everything but without success! If anyone can help me
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The INVALID SERIAL NUMBER error is usually associated with a NAND issue. This could be caused by a data corruption in the NAND or it could be physical damage to the soldered connections or even the NAND itself.
It may be repairable by someone who has a NAND programmer but this would require a micro-soldering repair.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
ANGE NKAPTSCHOUANG será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 77
