Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
Lcd shield plate on new display
Hello, try to be as brief as possible. a few months ago the screen of my iPhone broke, after looking for a place to make the change (there are no official stores in my country) they put a screen of very poor quality but functional. 15 days ago that screen broke and I decided to replace it in another place, in this new place they open the iPhone in my face and they show me that the lcd shield plate is not there and they explain to me that it is usually removed since very bad quality screens are not they need it. They also told me that if I got the lcd shield plate they would place it on the new screen. since then my screen of moments works well and of others I can not use since when wanting to type, other letters are activated and not the ones I am touching, for example. they explained to me that this could happen because if the lcd flex is not well positioned it could cause this effect, they replaced several screens several times and although the times in all the lcd varied the fault persisted. Is this possible? Is it only necessary to adjust the LCD shield plate correctly so that the screen works? they also offered to place another screen of lower quality in which worked Perfect except the 3D Touch
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I’ve already installed the shield plate and tried several lcds but all have the same problem. It’s posible that the maybe another thing is the problem ?
por
Adicionar um comentário
2 respostas
Solução escolhida
In my opinion, the LCD Shield Plate should be installed. This supplies some stability to the LCD and digitizer, also acts as a heat shield and probably has some other functions as well. Not replacing it is a sign of a low quality repair.
This part can be ordered and is easy to install. Personally, I would stay away from low cost/low quality replacement parts.
Esta resposta foi útil?
Pontuação 2
I've had one case where I had to install an iPhone 7 screen without the LCD shield plate, in any case at least some tape needs to be put in to keep the cable in place.
No issues with LCD display or touch on the aftermarket screen I installed. I guess that the screens they had were defective / faulty / low quality.
Pontuação 1
Adicionar a sua resposta
Elias Navarro será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 2,006
