cracked look in screen
my laptop has a layer that looks cracked not top layer it was leaned on
Esta é uma boa pergunta?
So your glass is okay but your LCD is cracked? Time to get a new display they are relative inexpensive http://www.lcdscreen.com/ppc-series-acer...
Esta resposta foi útil?
If you are not planning on replacing an LCD connect an external monitor using a VGA cable for output or if your TV has a VGA connector then you can even get the output on your TV.
You can buy a replacement LCD from eBay and take it to a local electrician and have it replaced for you
Good Luck.
Hopefully the OP fixed it within the last 2 years ;-)
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 2,156
