Ir para o conteúdo principal
Quinta geração da Pickup da Toyota
Tailgate handle not functioning - how to fix
The tailgate handle broke on my '94 Toyota p/u. I want to know if I have to undo all 12 screws on the tailgate door (inside bed) to get a peek inside and if that is the way in to fix the problem. Right now the tailgate won't open: the latch moves up/down with no resistance. My guess is that there is a piece inside that broke. So really 2 questions: how to open a broken tailgate and how to fix the handle?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
dana_orrick yes you have to remove those 12 screws. Those hold the service cover in place. Once removed you see what is broken etc. Of course, you can then also use it to open the tailgate.
Imagem
Imagem
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
dana_orrick será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 3,225
