[Solved]6s Battery Replacement - Now Home Button Is Not Working
'''[ Solved - It was the screen ]
My Sister handed down her fully working iPhone 6s to my Mum. Just needed a battery replacement. It has been factory reset.
I have done a couple of ipads and a few 5c so the task wasn't a issue.
Do the volume up/down buttons work on the "Hello" freshly factory reset screen? Home button and vol keys do not work. Power and ringer swtich do.
edit: Vol keys are working.
No visible damage.
Esta é uma boa pergunta?
3 comentários
-Reseated cables many times.
-Hard reset (Home/Power) doesn’t work.
-iTunes update and factory reset.
Touch screen is unresponsive at the 'quick start/manual set-up' screen but works at the ‘Hello’ screen: https://youtu.be/HkF7EnBLahI
por Brent
I think you need to test an other screen because of the cable for the homebutton goes in those flex cables of the screen.
por Jonny
It was the screen. Tested on a replacement. Thanks all.
por Brent
