Ir para o conteúdo principal
iPod Classic de 6ª geração. Modelo A1238 / disco rígido de 80, 120 ou 160 GB / parte frontal de metal preta ou prateada
Dead iPod- NOT the battery
iPod won't turn on, regardless of whether or not it is plugged into anything. The battery life is still in really good shape and was fully charged at the time it stopped working. Had walked to work with it on, left it in pocket, took off coat, then took out iPod to use in an audio system and it wouldn't turn on. Seems improbable it could randomly die in 5 minutes...
Esta é uma boa pergunta?
Pontuação 14
4 comentários
It worked, oldturkey. Thank you for protecting me from my own karma.
por
Thank you for accepting my answer. Wishing you the best of luck and keep on jamming:-)
por
Thank You It worked never thought of the on off button i tried everything else
Thanks Again
por
Your instructions worked miraculously! I really thought I had lost it (and all my recordings) forever. THANK YOU!
por
Adicionar um comentário
2 respostas
Solução escolhida
Yes, they can die from one minute to the next :-) Try to reset your iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
What happens when you plug it into your computer? If this does not work, you may have to take a closer look at it. Let us know how it is going. Good Luck
Esta resposta foi útil?
Pontuação 20
32 comentários:
Had same problem. Solution worked. Thank you very much.
por
awesome...problem solved...thanks
por
Nice. Thank you. Problem solved!
por
Thanks so much! worked perfectly
por
@Matt Tierney, you are welcome :)
por
Exibir mais 27 comentários
will I lose my tunes if I replace a dead hard drive on my apple iPod 5th generation
Pontuação 0
1 comentário:
Yea as this is where the "Tunes" are kept.
por
Adicionar a sua resposta
Danielle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 60
Ao todo: 50,343
