Ir para o conteúdo principal
Dicas e truques para aproveitar ao máximo o iFixit.
Re-magnetizing My Pro Tech Toolkit Screwdriver?
I have an iFixit Pro Tech toolkit and after awhile, the magnet inside has felt like it isn't picking up screws with as much strength as it did when I first got it. Is there any way to re-magnetize it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
This is what I use to magnetize or demagnetize tools:
Magnetizer / Demagnetizer
Imagem de Magnetizes and demagnetizes small tools and screwdriver bits.
Produto
$8.99
Esta resposta foi útil?
Pontuação 5
Yes, it's actually quite easy.
Find a magnet (i.e. a speaker inside a PC case).
Simply tap the screwdriver tip against the magnet and quickly remove the tip once you tap it.
It may take a few tries, but if you tap it by touching and very quickly removing the tip, you have just magnetized your screwdriver.
Pontuação 4
Hi @reddaugherty ,
Alternatively as ifixit has a lifetime warranty on their tools you may wish to contact them about it and possibly get a replacement tool
Pontuação 2
Adicionar a sua resposta
Ryan Daugherty será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 66
Ao todo: 4,733
