How to replace front glass?
I would really appreciate a guide on how to replace the front glass for my daughter's 2014 kindle. thank you in advance foe any help.
Esta é uma boa pergunta?
you are not telling us the exact Kindle that you need help with . The device you picked is the FireHD 7 and you can use this guide Substituição da tela do Amazon Fire HD 7 (4ª Geração) for that
matthew santiago you will have to follow the above guide in its entirety. You then need a heat-source like a good hairdryer or a hot air gun at it's lowest settings to soften the adhesive that holds the touch screen to the frame. Soften it with the heat-source and remove the touch screen with same plastic tools like guitar picks etc. Check this video from 7:54 and proceed identically to it.
Esta resposta foi útil?
I am requesting info on repairing the glass, not the LCD.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 806
1 comentário
This question is in the Amazon fire hd 7 section.
por matthew santiago Compartilhar
