Ir para o conteúdo principal
Amazon Fire HD 7 (4th Generation) Display Replacement
O que você precisa
    1. Amazon Fire HD 7 (4th Generation) Display Replacement, Motherboard: passo 1, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement, Motherboard: passo 1, imagem 2 %32 Amazon Fire HD 7 (4th Generation) Display Replacement, Motherboard: passo 1, imagem 3 %32
      • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
      • Work your way around the device to free all the clips.
      Pergunte ao FixBot
      Comentar
    2. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 2, imagem 1 %32
      • Once all clips have been released, remove the back case to reveal the inside of the device.
      Pergunte ao FixBot
      Comentar
    3. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 3, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 3, imagem 2 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 3, imagem 3 %32
      • Remove the nine silver screws located around the motherboard with the T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 4, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 4, imagem 2 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 4, imagem 3 %32
      • Remove the six black screws located around the battery and the speaker with the T5 Torx screwdriver.
      • Make your way around the battery and speaker to remove all of them.
      Pergunte ao FixBot
      Comentar
    5. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 5, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 5, imagem 2 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 5, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Carefully unplug the three wire connections by placing a plastic spudger under the connections and lifting up.
      • Disconnect the battery and speaker connections by placing the round handle spudger under the wires and lifting up and out.
      • Disconnect the display connections from the motherboard by using the plastic spudger to lift the clamp holding the ribbon cable. Then, using the tweezers, grab the ribbon wire and pull away from the motherboard.
      Pergunte ao FixBot
      Comentar
    6. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 6, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 6, imagem 2 %32
      • Remove the two screws holding the rear camera in place using the T5 Torx screwdriver.
      • Once freed from the screws, gently lift and remove the rear camera.
      • The camera lens is sensitive. Be careful when removing and handling the rear camera.
      Pergunte ao FixBot
      Comentar
    7. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 7, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 7, imagem 2 %32
      • Now the motherboard is free to be removed.
      • Lift the motherboard up to remove it as shown in the picture.
      Pergunte ao FixBot
      Comentar
    1. Amazon Fire HD 7 (4th Generation) Display Replacement, Display: passo 8, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement, Display: passo 8, imagem 2 %32 Amazon Fire HD 7 (4th Generation) Display Replacement, Display: passo 8, imagem 3 %32
      • Following the bottom edge of the device, remove the (3) T5 hex silver screws with the T5 torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 9, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 9, imagem 2 %32
      • The motherboard chassis can now be removed to reveal the display screen.
      • Remove the volume button components.
      Pergunte ao FixBot
      Comentar
    3. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 10, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 10, imagem 2 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 10, imagem 3 %32
      • Remove the (4) T5 hex silver screws in the corners of the display screen using the T5 torx screwdriver.
      Pergunte ao FixBot
      Comentar
    4. Amazon Fire HD 7 (4th Generation) Display Replacement: passo 11, imagem 1 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 11, imagem 2 %32 Amazon Fire HD 7 (4th Generation) Display Replacement: passo 11, imagem 3 %32
      • The LCD display screen may now be removed and replaced.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
7 outras pessoas executaram este guia.
Omir Rosado
Membro desde: 09/30/16
752 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-4, Passmore Fall 2016 Membro de USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
4 Membros
Autoria de 10 guias
1Comentário do guia
finding it very difficult to source a new touch screen for this model.
colin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 64
Ao todo: 8,025
