Ir para o conteúdo principal
Informações de reparo para a impressora fotográfica jato de tinta colorida Canon PIXMA iP4700. Lançada em 2010. Número do modelo: iP4700.
My printer is having problems Printing.
My ip4700 is printing very faint lines or not at all. This is mostly the black print but the colors are having similar issues.
I did a nozzle check and it was perfect. Everything printed fine. The instructions say not to do a cleaning if the nozzle check is okay.
Any ideas? Thanks.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @dreemsnake ,
What happens if you copy or scan a document using the printer's control panel, does it print OK?
If it does and you are only having problems when printing from a computer, what OS is installed in the computer and how is it connected to the printer, wireless or cable?
por
Adicionar um comentário
1 resposta
I would suggest running a cleaning a couple times, and if that doesn't resolve the issue, try replacing the ink cartridges.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
lori será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 811
