Put in 2000mAH big battery in iPod 3gb
hello can i put in a bigger battery in the ipod 30gb 5 gen , like a 2000maH or an iphone 5 battery??? where can i find such a bigger battery for the ipod video 5gen???
Esta é uma boa pergunta?
valantis sourlis no you cannot. The space is extremely limited on this model. You must stay with the original battery. If you want to update to a battery from a 60GB or more of the same generation you need to replace the back cover since it is deeper to accommodate even that small size difference.
Esta resposta foi útil?
If your battery life seems shorter than it used to be, you can replace it! iPod 5th Generation (Video) Battery Replacement
i tried ordering it on ifixit eu store but it says not available, where can i get a big battery else where for shipping to europe?? want a good quality one,also is there a cheap way to put more gb in the ipod???
iPod 5th Generation (Video) Hard Drive Replacement This guide will show you how to replace your HDD with a new one, But I cannot get the price for you on the EU store because its in a different language. (google translate extension is only translating some of the pages)
Just trying to think out side of the box here. You can add a bigger battery if you are creative. It may not look pretty but all you need is a external battery for example. Use adhesive or place it in a separate pocket.
If you flash mod the ipod, there's a lot of extra space. Then you can get a big chungas battery if you want.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 666
