My beats won’t turn on at all. No LED lights turn at at all
My beats are not charging and not turning on. No LED lights at all, even charged overnight and nothing. I have tried resetting but nothing works. Please help!
Esta é uma boa pergunta?
@nikkinew not charging and not turning on could be a few things. Check the charging port to make sure it is without any debris or obstruction and check your cable. If all of that checks out okay you want to go ahead and replace the battery. It is possible that the battery no longer accepts/holds a charge. Use this teardown Desmontagem do Beats Solo 2 Wireless to get to it. This will also provide you with a known-well starting point in case more troubleshooting will be necessary
Esta resposta foi útil?
Link is irrelevant pdf of IC CSR8670 I/O pin suggested use.
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 24,233
