Ir para o conteúdo principal
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
379 Perguntas Visualizar todos
Controller wont charge or power on
I'm trying to fix my friends Dualshock 4 but I can't seem to figure out the issue. I've never tried to fix a Dualschock controller so I could just be missing something.
The controller will not charge at all (light bar wont turn on either). I have replaced the battery and the USB charging port alongside with the ribbon that connects the port to the board. Nothing happened when I replaced the battery, but after replacing the USB port I noticed that the controller circuit board was getting hotter when I had the USB plugged in. Although, the controller still wont charge or turn on.
I was just wondering if anybody had any suggestions on what the issue and fix could be.
Thanks,
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Hi Trevor,
This troubleshooting wiki might give you some suggestions on what else to try. It looks like replacing the USB charging port is a last-resort thing to try, and it sounds like it may have made things more complicated for you.
As always, good luck!
Esta resposta foi útil?
Pontuação 0
Maybe you have the same issue is my controller where the Touchpad makes the controller unusable? And disconnect the Touchpad makes it work again.
DualShock 4 seams death when Touchpad is connected
Pontuação 0
Ive replaced the battery, ribbon and charging port. The controller flashes and shows it's charging. But it DOES NOT CHARGE.
FRUSTRATING ARRRRRGH. !!
Pontuação 0
Adicionar a sua resposta
Trevor Corbin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 7,620
