Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Why is my iPhone 7 boot looping after a screen replacement?
So a few days ago i bought a used iphone online. It had a cracked screen but worked just fine. I ordered a new screen and replaced it. After replacing it the problems started to happen. It would continuously boot loop.
I've tried to restore it using itunes several times. Sometimes it worked, but i couldn't get past the "hello" screen as the home button doesn't work anymore... I had to turn it back off in hopes it would start at language selection screen. Unfortunately, almost every time it shuts off it would go back into a boot loop. I've tried reconnecting the old screen too, but it's still boot looping.
I'm wondering if this is a software issue or if it's a hardware issue. If it is a hardware issue, is it the screen that sends it into a boot loop or can it be due to something else?
Any help would be much appreciated!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
A lot of things can cause boot-looping. However a clue in your comments is that when everything did work fine (sort of) that the Home Button didn't work. You may have slightly damaged the Home Button when you replaced the screen and migrated the Home Button over.
I would open up the phone and closely inspect with magnification the Home Button, especially the flex cable for any damage or tears. Follow this guide. I would also closely inspect the connectors for the screen assembly.
Esta resposta foi útil?
Pontuação 4
Did you try updating your software? iOS 11 has had issues with replacement screens. The newer ios’s Is supposed to fix those issues. Put it in safe mode and update.
Pontuação 0
Same issue here. Everything works fine but i can’t make a call or it goes into boot loop. I think its an apple scam to get me to buy a new phone
Pontuação 0
Adicionar a sua resposta
JAB será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 7,564
