How to remove prong from external speaker jack
male rca jack broke off inside female rca on rear panel. how do i get it out?
Esta é uma boa pergunta?
@budlight use a drill bit just a bit smaller than the center pin and use either your fingers or a hand drill to gently advance the bit into the pin. Once the bit binds inside the pin you can pulll it out. It'll take a bit of practice and some fiddling but it'll work. Stay away from any kind of power tools since that can destroy the board connector.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 173
