Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
Unable to flash iOS (Different errors on 3u and iTunes
Hi,
Wondered if someone could help me.
My iPhone 5c wont flash with 3uTools as it comes up with
ERROR: Unable to restore iDevice(-1).
Its at 80% on updating baseband
With iTunes it says
The iPhone "iPhone" could not be restored. An unknown error occurred (50).
I am using a genuine apple USB to my PC.
Esta é uma boa pergunta?
Pontuação 5
2 comentários
IPhone stop's flashing at 16% no error, but just loading
por
Adicionar um comentário
5 respostas
Solução escolhida
Is there a reason you were trying to flash your iPhone? Normally, a -1 error is baseband related and this could be indicative of a damaged baseband IC or it's solder connections. Has the phone been dropped much over its lifespan? Has it come into contact with water?
Esta resposta foi útil?
Pontuação 3
2 comentários:
I was updating iOS and it didn't complete.
It apparently took a flight down some stairs.
por
Then it's highly likely there is a bad solder joint on the baseband chip. A micro solder should be able to fix it by reflow / reball.
por
Error -1 on 3uTools may be caused by USB cable connection, network and baseband.
Try to change the usb cable, confirm the network connection. If error still exists, you would need to change the baseband.
Pontuação 2
1 comentário:
por
I have same problem!
I changed my screen replacement and battery, after this operation was succesfull the device.
But after while i did software update, it is crashed i mean the system trying rebooting all the time but nothing else.
I did it with itunes connection, i called the apple support but they didn’t helped what is the problem. I don’t remember the error code, but my phone can’t boot.
I turned off the find my phone and logout from device.
The flash with 3uTools it’s going to 19% and over.
Anybody help?
Pontuação 0
2 comentários:
I have the same problem I bet it is a bad connection I am going to open it back up and check to see if I did not put a connector on correctly
por
have the same problem 3utools stuck at 19%
por
I’m using 3utolls for flashing iphone but my iphone is connected with 3utools but flash and jailbreak option show network connection error. Anybody tell me what am i do.
Pontuação 0
1 comentário:
Change your firmware source and redownload it then restore again
por
Hi i am iphone 7 plus flash i flash errilla -53 u have 60 percent may i guide my guide
Pontuação 0
Adicionar a sua resposta
Jaymie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 34
Ao todo: 28,629
