LCD display goes blank when I move it out to use it at an angle
With the display in the normal position it works. As soon as the display is pulled out to angle it the lower edge drops down on the hinged mechanism as designed, but when this happens the screen goes blank. If I use my hand to hold the screen up as I pull it out the display works as normal. I think there is a connection under the LCD which is causing the problem when the screen slides down. I am worried I may break the camera if I take the display apart as I have no manual. Has anyone come across this problem and is there a fix for it?
Thanks
Esta é uma boa pergunta?
