Ir para o conteúdo principal
Disassembly Guide
O que você precisa
    1. Disassembly Guide, Battery: passo 1, imagem 1 %32 Disassembly Guide, Battery: passo 1, imagem 2 %32 Disassembly Guide, Battery: passo 1, imagem 3 %32
      • Locate the battery housing cover on the bottom of your camera.
      • Place a finger on the textured portion of the battery housing cover.
      • Slide the cover in the direction that the arrow is pointing.
      Pergunte ao FixBot
      Comentar
    2. Disassembly Guide: passo 2, imagem 1 %32 Disassembly Guide: passo 2, imagem 2 %32
      • Use your finger to pivot the orange tab away from the battery.
      Pergunte ao FixBot
      Comentar
    3. Disassembly Guide: passo 3, imagem 1 %32
      • Pull the battery out of the housing with your fingers.
      Pergunte ao FixBot
      Comentar
    1. Disassembly Guide, Motherboard: passo 4, imagem 1 %32 Disassembly Guide, Motherboard: passo 4, imagem 2 %32
      • Remove the two 4mm Hex screws that connect the grip to the camera with a Hex head screwdriver.
      • Remove the two Phillips screws to the left of the hex screws with a Phillips head screwdriver:
      • One 2mm screw
      • One 3mm screw
      • Remove the grip from the front of the camera by pulling it away from the lens and then away from the camera.
      Pergunte ao FixBot
      Comentar
    2. Disassembly Guide: passo 5, imagem 1 %32
      • Remove the following three Philips screws from the flash release side of the camera with a Philips Head screwdriver:
      • One 2.5mm screw
      • One 4.5mm screw
      • One 1.75mm screw
      Pergunte ao FixBot
      Comentar
    3. Disassembly Guide: passo 6, imagem 1 %32
      • Remove the following three Philips screws from the bottom of the camera with a Philips Head screwdriver:
      • One 3.25mm screw
      • One 2.5mm screw
      • One 2.75mm screw
      Pergunte ao FixBot
      Comentar
    4. Disassembly Guide: passo 7, imagem 1 %32 Disassembly Guide: passo 7, imagem 2 %32
      • Rotate the LCD screen away from the camera.
      Pergunte ao FixBot
      Comentar
    5. Disassembly Guide: passo 8, imagem 1 %32
      • Remove the following four Phillips screws securing the back panel with a Philips Head screwdriver:
      • Two 3 mm screws
      • One 2mm screw
      • One 2.5 mm screw
      Pergunte ao FixBot
      Comentar
    6. Disassembly Guide: passo 9, imagem 1 %32
      • Lift the back casing up far enough to expose the ribbon cables.
      Pergunte ao FixBot
      Comentar
    7. Disassembly Guide: passo 10, imagem 1 %32 Disassembly Guide: passo 10, imagem 2 %32
      • Use a plastic spudger to gently release the locking tab holding the ribbon cable, closest to the edge of the camera, in place.
      • Repeat this process for the second ribbon cable to the right.
      • Carefully lift the back casing away from the camera.
      Pergunte ao FixBot
      Comentar
    8. Disassembly Guide: passo 11, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    9. Disassembly Guide: passo 12, imagem 1 %32 Disassembly Guide: passo 12, imagem 2 %32
      • Remove the five Phillips screws that are attached to the copper plate with a Philips Head screwdriver:
      • Two 3mm screws
      • Two 1.5mm screws
      • One 4mm screw
      • Lift the copper plate away from the camera.
      Pergunte ao FixBot
      Comentar
    10. Disassembly Guide: passo 13, imagem 1 %32 Disassembly Guide: passo 13, imagem 2 %32 Disassembly Guide: passo 13, imagem 3 %32
      • Remove the following three Phillips screws securing the silver plate with a Philips Head screwdriver:
      • Two 2.9mm screws on the front of the camera
      • One 1.8mm screw on the bottom of the camera
      • Lift the silver plate away from the camera.
      Pergunte ao FixBot
      Comentar
    11. Disassembly Guide: passo 14, imagem 1 %32 Disassembly Guide: passo 14, imagem 2 %32
      • Use the plastic spudger to lift up both sides of the ribbon cable from its connector pins.
      • The male end is on the left and the female end is on the right. The right side of the cable is notched.
      Pergunte ao FixBot
      Comentar
    12. Disassembly Guide: passo 15, imagem 1 %32 Disassembly Guide: passo 15, imagem 2 %32 Disassembly Guide: passo 15, imagem 3 %32
      • Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable.
      • Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing.
      • Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
      • Both ribbon cables should be removed after this step.
      Pergunte ao FixBot
      Comentar
    13. Disassembly Guide: passo 16, imagem 1 %32 Disassembly Guide: passo 16, imagem 2 %32
      • Release the flash by sliding the flash release towards the lens.
      • The flash release is located on the side of the camera closest to the lens.
      Pergunte ao FixBot
      Comentar
    14. Disassembly Guide: passo 17, imagem 1 %32 Disassembly Guide: passo 17, imagem 2 %32
      • Remove the following two Phillips screws from the flash cavity with a Philips Head screwdriver:
      • Remove the 2mm screw to the right of the flash.
      • Remove the 2.5mm screw to the left of the flash.
      Pergunte ao FixBot
      Comentar
    15. Disassembly Guide: passo 18, imagem 1 %32 Disassembly Guide: passo 18, imagem 2 %32
      • Remove the 2.5mm Phillips screw from the front plate with a Phillips head screwdriver.
      • Pull up on the top portion of the camera to separate the top casing from the camera body.
      • Make sure the flash is up. Otherwise the top casing will not release.
      Pergunte ao FixBot
      Comentar
    16. Disassembly Guide: passo 19, imagem 1 %32 Disassembly Guide: passo 19, imagem 2 %32
      • Remove the 3.5mm Phillips screw from the grey tab on the top of the camera with a Philips Head screwdriver.
      • Rotate the camera so the back panel is facing you.
      • Remove the 1.4mm Phillips screw from the sliver tab near the top of the camera with a Philips Head screwdriver.
      Pergunte ao FixBot
      Comentar
    17. Disassembly Guide: passo 20, imagem 1 %32 Disassembly Guide: passo 20, imagem 2 %32
      • Use the flat end of the plastic spudger to release the plastic retaining clip on the side plate closest to the lens.
      • Rotate the side plate closest to the lens toward the lens of the camera and then pull the plate away from the camera.
      Pergunte ao FixBot
      Comentar
    18. Disassembly Guide: passo 21, imagem 1 %32 Disassembly Guide: passo 21, imagem 2 %32 Disassembly Guide: passo 21, imagem 3 %32
      Ferramenta utilizada neste passo:
      • Release the plastic locking tab of the upper ribbon cable with the plastic spudger.
      • Pull the top ribbon cable from its mount with the fine tip metal tweezers.
      • Remove the bottom ribbon cable with the fine tip metal tweezers by pulling it toward the flash switch side of the camera.
      • The bottom ribbon cable does not have a locking tab; it simply slides in and out.
      Pergunte ao FixBot
      Comentar
    19. Disassembly Guide: passo 22, imagem 1 %32
      • Pull the front plate off the camera body.
      • It should slide off easily. If it does not, ensure that all screws and ribbon cables from previous steps have been removed or disconnected.
      Pergunte ao FixBot
      Comentar
    20. Disassembly Guide: passo 23, imagem 1 %32
      • Remove the rubber dust cover from the camera by moving the hooks away from the three prongs holding them in place and then pulling the cover away from the camera.
      Pergunte ao FixBot
      Comentar
    21. Disassembly Guide: passo 24, imagem 1 %32 Disassembly Guide: passo 24, imagem 2 %32
      • Remove the following two Phillips screws from the side of the camera with the three connector ports with a Phillips head screwdriver:
      • One 2.5mm screw
      • One 3.3mm screw
      • Pull the metal shield away from the camera.
      Pergunte ao FixBot
      Comentar
    22. Disassembly Guide: passo 25, imagem 1 %32 Disassembly Guide: passo 25, imagem 2 %32 Disassembly Guide: passo 25, imagem 3 %32
      • Use the plastic spudger to remove the ribbon cable from the motherboard by placing the spudger under the ribbon cable connector and pulling up.
      • Remove the 2.8mm screw from the motherboard.
      • Do not try to remove the motherboard from the camera yet.
      • Carefully rotate the motherboard upward.
      • Use the plastic spudger to remove the ribbon cable from the bottom of the motherboard by placing the spudger under the ribbon cable connector and pulling up.
      Pergunte ao FixBot
      Comentar
    23. Disassembly Guide: passo 26, imagem 1 %32
      • Lift the motherboard away from the camera.
      Pergunte ao FixBot
      Comentar
    1. Disassembly Guide, Lens: passo 27, imagem 1 %32 Disassembly Guide, Lens: passo 27, imagem 2 %32 Disassembly Guide, Lens: passo 27, imagem 3 %32
      • Lay the camera on a flat surface while performing these steps because removing the frame causes the camera to fall apart.
      • Remove the four 4.25mm Philips screws from the silver frame that surrounds the lens of the camera with a Philips Head screwdriver.
      • Remove the frame by lifting straight up.
      Pergunte ao FixBot
      Comentar
    2. Disassembly Guide: passo 28, imagem 1 %32
      • Separate the lens from the other components of the camera.
      Pergunte ao FixBot
      Comentar
    1. Disassembly Guide, Disassembly Guide: passo 29, imagem 1 %32
      • You have disassembled the Canon PowerShot G1 X Mark II!
      Pergunte ao FixBot
      Comentar
Conclusão
7 outras pessoas executaram este guia.
Ryan Dunn
Membro desde: 01/12/16
578 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 70-2, Forte Winter 2016 Membro de Cal Poly, Team 70-2, Forte Winter 2016
CPSU-FORTE-W16S70G2
4 Membros
Autoria de 4 guias
5Comentários do guia
Surely these are JIS screws not Phillips. A Phillips screwdriver will chew the heads up.
maico61 - Responder Compartilhar
I have an LCD display problem and would like to disassemble it, the guide does not cover anything to do with the LDC assembly, otherwise a very good guide. I’ll attempt it anyway once I feel like a risk.
Alan Cattalon - Responder Compartilhar
Fabuloso. La pantalla de mi camara canon gx1 cuando la invertias se apagaba. Lo que he hecho fue comprar un cable ribbon nuevo en aliexpress y substituirlo. Asunto arreglado por 7euros.
En este tutorial, falta como desmontar la pantalla. Para hacerlo debes retirar los tornillos de la pantalla con delicadeza, despegar el cable con delicadeza y montar la pantalla otra vez.
MIGUEL A. MARTINEZ GOMEZ - Responder Compartilhar
hola miguel angel, cual es ese cable? podrias enlazarlo, mi pantalla da fallos y debe ser ese ribbon. gracias!
alvarezrodriguezrc - Responder Compartilhar
Thanks for this great guide ! I need to disassemble and clean the external flash connector in the top portion of the camera because of some dirt and even corrosion - I found no way how to do this, I removed all screws but I was not able to remove the metallic structure. Any idea to take this apart ? thanks in advance...
M Df - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 65
Ao todo: 11,901
