Ir para o conteúdo principal
O Atari 2600, ou Atari Video Computer System (VCS), é um console de videogame lançado em setembro de 1977. O 2600 utiliza um CPU MOS Technology 6507 e utiliza cartuchos ROM para armazenar jogos.
What kind of cable is This?
Imagem
This cable is for my Atari, but I need another one for my Sega Master System, i wanted to know what the cable is called. People call it a RF Input, but for some reason the cable is not called a rf cable so I don't know how to search up this exact cable
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@krisow those are RCA cables
Update (11/11/2017)
You can still use the RCA cable. Check on here or on here for a replacement
Esta resposta foi útil?
Pontuação 2
1 comentário:
I've searched that cable up on Ebay and its not the right cable sadly, they're very alike, but not the same
por
It is called an RF video cable. You can find them on Amazon just look up the term RF video game cord or cable .
And RCA cable would be a temporary fix. However you would get a little bit of a loss of signal because of the make up of the center core of the wire, it is a little thicker and has an 8 ohm impedance. The RCA contact on the outside is a little thinner as well versus the thicker contacts on the standard RF cable.
Pontuação 0
Adicionar a sua resposta
Krisander 1998 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 36
Ao todo: 1,405
