Ir para o conteúdo principal
Two red line on the screen
Hi dears,
few days back i found a red line on my Screen which not effect the pixels and appear only in any white background.
The support center they said i need to replace the screen
Is there any solution for that?
Imagem
Imagem
help please.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@alitawash those do like a TAB error. That is where the bond between the thin ribbon cable and the panel fails. You can try and apply some pressure right above the lines and see if they then disappear. Of course it is best done with the back of the TV removed. Here is an image to show you the TAB bonds.
Imagem
There is really no fix for it since it requires a special repair. Sometimes it can be temporarily be resolved by continuing to apply pressure to the bond with some tape etc.
If you can, take some pictures and post those with your question. That way we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
alitawash será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 833
