Stuck in zoom position
my camera is stuck in the zoom position. it will not go back to the home position. the message on the screen reads: turn camera off. remove lens cap or obstruction and turn camera on. I don't have the lens cap on nor do I see anything in or around the lens that could be causing the issue.
Esta é uma boa pergunta?
have you tried re-seating the lens?
are the connection Pins clean? could be a connection issue.
por tri5kmark Compartilhar
I think it is the inner manchet of the zoomlens causing friction. I have the same issue and now the camera will not even switch on anymore.
por mw120970 Compartilhar
