Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
Backside Metal or Plastic?
Is the iPhone 8's backside under the glass of metal or plastic?
Thank you.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
5 respostas
Solução escolhida
The outer housing (perimeter) is aluminum while the inner back plate is stainless steel. Check out this teardown guide.
Esta resposta foi útil?
Pontuação 3
1 comentário:
@danj is correct, I have amended my answer...
por
It looks like steel to me.
The spot welds along the edge of the studs are bluish which is what steel would look like. In addition the thinness of the metal given the needed strength would imply steel as well. True the outer side edge is anodized aluminum!
Pontuação 2
It is metal. See this phone
Pontuação 1
1 comentário:
Mandy you are correct. It is made from stainless steel.
por
Hi, the back is metal with a frame (Al) and covered with Glass.
Pontuação 0
It is metal covered with glass, however i don,t recommend this phone if you want a strong one a video from the channel jerryrigeverything the back glass broke dramatically after only the second from lap fall . If you a good powerful phone i would recommend the xperia xz premium.
Pontuação -1
Adicionar a sua resposta
Hans será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 814
