Ir para o conteúdo principal
Guias de reparo para as variações do laptop Compaq Presario CQ62. Esta marca foi fabricada de 1993 a 2013 e pertenceu à HP de 2002 a 2013.
Why is my computer so slow?
Presario CQ62
Why does my computer run so slowly?
Other computers in the house arent ao extremely slow.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Hi @grandmalou ,
What OS is installed in the laptop?
What have you checked so far to see why it is slow?
por
@jayeff Have a look at this: https://www.cnet.com/products/hp-compaq-... If these are the specs of his laptop then no wonder why it's slow :))
por
Hi @alexniculescu ,
Agreed specs aren't the greatest but then again there is slow and there is sloooow.
There could be other things affecting the performance. As you know the list goes on and on.
Cheers ;-)
por
Adicionar um comentário
1 resposta
Looking at the specs, it is 100% your RAM. Spend some money and make sure it supports your laptop and upgrade to 8GB's of RAM. Your max supported is 8 and it comes with 2GB. With that RAM amount, if you ever trying to open more than 1 thing then it will slow down dramatically, even multiple tabs on a browser. Not enough to multitask. The CPU is fine.
Upgrade that to 8GB and I assure you it will many times faster and smooth sailing. :)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lou será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 1,542
