Ir para o conteúdo principal
Lançado originalmente em 2005, o iDog é um brinquedo MP3 fabricado pela Sega e distribuído pela Hasbro nos EUA.
Will Not Interact/Play Music/Make Sound
Found my old 2007 Amp'd version I put 3 new batteries in it and it will turn on but u cant hardly see the LED lights and it wont play music or bark wine or anything sound at all except a ticking sort of sound. I have tried the nose button and the tail and even held the reset button. It wont turn off by holding the nose button either. The only time it makes a sound is when I switch it to DEMO mode and it will play lik 2-3 seconds of music and will bark but then goes silent again. I have checked where you put the batteries and it immaculate no corrosion or anything. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @vickisworld ,
Here is a link to the ifixit Desmontagem de um brinquedo iDog MP3 repair.
It shows how to open the toy so that access can be gained to the electronics.
Once it has been opened you can check the wiring using a DMM (Digital Voltmeter and also an Ohmmeter) to try an isolate where the problem is. Unfortunately I cannot find a wiring diagram for the toy which would greatly simplify this process.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Gabbi Findley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 32
Ao todo: 1,465
