Ir para o conteúdo principal
O Dell Inspiron 11-3147 é um notebook híbrido de 11 polegadas que também funciona como tablet. A tela pode ser dobrada para trás para permitir o uso portátil. Foi fabricado pela Dell em agosto de 2015.
Three beeps upon startup
Does not boot and instead get three beeps. Given three different possible solutions: Chipset Error (North and South bridge error)
Time-Of-Day Clock test failure
Gate A20 failure
Super I/O chip failure
Keyboard controller failure
How would I go about testing which one of those would be causing the issue? The website says to run Dell's diagnostics tool but it won't even boot up far enough for me to access that.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@inlerah start by removing the battery, the AC adapter and the RAM then hold the power button down for a while. Replace the AC adapter and see if it starts up. You also want to try a USB keyboard and see if that makes a difference. If not then I would suggest that you replace the RTC battery first and try to start it up after that. Use this guide Substituição da bateria CMOS do Dell Inspiron 11-3147 for that.
Any of this
Gate A20 failure
would require boardlevel repair and for that you need to let us know what exact motherboard your computer has.
Update (10/21/2017)
@inlerah have you tried a different memory module? You do want to rule out that you have a bad module. Your motherboard should have a few numbers silk screened on the board. Just give us those numbers or post some really good pictures of your board with your question. You can use this guide Adicionar imagens a uma pergunta já existente to do so.
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Dell Inspiron 11-3147 Bateria CMOS
Guia
Fácil
10 minutes
Esta resposta foi útil?
Pontuação 2
1 comentário:
(Late response, had to wait until drivers of the right size got delivered) So I did this and I got back a "No ram detected" beep code. Where should I be going from here?
Also, I can get you the motherboard type...just need to know where to get that info from.
por Compartilhar
Adicionar a sua resposta
William C Ward será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 868
