Ir para o conteúdo principal
Laptop gamer lançado em 2014 com uma placa gráfica Nvidia 860M e uma tela de 15,6". Atualizado em 2015 com placa gráfica 960M.
Replacing the charging port
The charging port on my Lenovo Y50 recently burnt out (it has visible scorch marks) I ordered a new one, but I am having troubles figuring out how to get the old one out and the new one in. The cable appears to go under the motherboard where I can't access it, so do I have to remove the board to replace the port? I tried giving the cable a light tug but it is firmly in place on the other side of the motherboard.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Josh Neumann sure sounds like you have to replace the motherboard. Download the maintenance manual from here https://download.lenovo.com/consumer/mob... You could also consider this video
Esta resposta foi útil?
Pontuação 1
Little late for you now i know, but for future curiousity- I" I just snipped one end off and slowly/carefuly pulled it out !and ran the new one on top the MB in a little slot and tact it down on a corner with the battery"(never had any issues)
Pontuação 0
1 comentário:
Hi Greg, I've got the same problem, definitely no chance of a short circuit?
por
I have the same problem, but i guess that:Yeah you have to open it. I ordered mine 2 days ago, i hope my laptop works . Good luck.
Pontuação 0
Adicionar a sua resposta
Josh Neumann será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 3,390
