Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2266 Perguntas Visualizar todos
Why my iPhone won't boot?
my iphone 7 fell into the toilet and doesn't work anymore.
iphone boot up but it stuck on apple logo .
if i try to connect iphone to the computer in every ways, recovery mode, dfu mode, normally, computer doesn't recognize it.
please help me
thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Your phone was either damaged from falling on the hard porcelain or from getting infiltrated by water, possibly a bit of both. Even though the iPhone 7 is water resistant, it is still possible some water got inside. At this point the phone must be opened and cleaned properly asap.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
If the phone still doesn't work, then a micro-soldering repair shop can properly troubleshoot your phone.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Emanuele Amantia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 82
