Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Perguntas Visualizar todos
How to fix screen flicker MacBook Pro (Retina, 15-inch, Mid 2015)?
Screen started on permaflicker yesterday. Had intermittent issues for a day or two prior. No know drops or blows to the maching. Display on external monitor is fine, screenshots do not capture any of the dipslay issues. Seems to be LCD / hardware related I think. Got tools on the way to crack into it and see if anythings loose. About 6 months out of warranty. Any other suggestions?
http://jciproof.us/7ZzzDF/lElIRHFT
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Adicionar um comentário
2 respostas
Solução escolhida
Oh Boy you got it bad!
Your issue is likely the lid assembly got a good bang damaging it. To be sure your image should be clear using an external display. If thats the case, follow this IFIXIT guide: MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement and here's the part you'll need:
Or from here:
Imagem de MacBook Pro 15" Retina (Mid 2015) Display Assembly
Produto
$519.99
Esta resposta foi útil?
Pontuação 2
Hi there! I think I have the same issue on the MacBook Pro (Retina, 13-inch, Mid 2014) and I want to see if I can fix it myself. Is there a guide for my model?
Pontuação 0
1 comentário:
@pavlo15914 - Here you go! MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement
Here's the listing for all our guides for Mac stuff Mac so you can locate what you need for anything else.
por
Adicionar a sua resposta
Curtis Baker será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 57,519
