Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
Should I replace the battery?
Hello there, I got a dead iPhone 7, so I tested the battery, and the only “weird” thing.. is that the battery is rated 3.8v… and on this one.. im having a reading of 4.1V…. maybe this overpowered issue is preventing the iPhone to turn on???
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
No, your battery is fine. A fully charged 3.8V battery will typically measure ~4.2V.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Ohhh nice.. so there's anything I can check of why the phone is not turning on??? or it seems to be the logicboard that its fried?
por
You should give me more information on the history of the phone. what happened to it before it died, was it dropped, damaged, contact with water, repaired etc.
por
Well my sister says... that it was dropped, but several months before she was using it normally, one night she plugged the phone... and next morning she noticed the phone was off... and since that morning... the phone is off =(
por
There's a good possibility that the logic board suffered some damage, either physically or electronically. Sometimes the problem shows up right away, other times it only appears later on.
This type of problem requires a micro-soldering repair and is not a DIY fix.
por
Oh I seee... thanks god I got a friend specialized in micro soldering on apple devices... but thanks for you super help =)
por
Adicionar a sua resposta
jbermudez27 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 212
