Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
White Screen of Death, HELP!
My phone faded into a plain white screen and I can't do anything. I'm currently waiting for the battery to drain but right now it seems to be just stuck at a white screen. I've looked it up and people are saying to hold down the power button and home button together but my power button doesn't work. I do not wish to open up my iphone3gs either unless I really really have to. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
That's a good answer @secondlife , no need to put it only as a comment.
por
Adicionar um comentário
1 resposta
Was there an event that triggered this -- dropping it, sitting on it, getting it wet, a repair done to it, etc?
I think you're going to have to bite the bullet and open it up. I would disconnect the battery (to force the shut down), brush/blow out all the dust, reseat all of the display cables, then reconnect the battery and see what happens. If the display comes back, you may want to buy a replacement power button flex cable; ebay has them for about $5. And since you're opening it up anyway you may also want to consider replacing the battery, which is also pretty cheap.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nia Tepplin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 52
