Ir para o conteúdo principal
Guias de reparo e suporte para a primeira geração do Nissan Murano, de 2003 a 2007.
Grounding Points on 2005
I have a 2005 Nissan Murano and I am having a few issues with sensors and my engine running really rich. I was advised by a mechanic friend that the issue could be caused by a bad ground. I am trying to find all the grounding points on my SL Murano. I have only been able to find 2. 1 below the battery and 1 off the timing chain housing.
Any suggestions? or could i just run new grounds from the battery?
Thanks,
Jarrett
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Sande Jarrett it would probably be easier to run a new ground than trying to find a bad one. Make sure you remove all paint and primer before applying a new ground and use some self tapping screws to attach it.
Now if you really, really want to know where all the ground points are, here is the manual for that :-) Nissan-Murano-Ground-Distribution.pdf
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks!!! this is really helpful.
por
Adicionar a sua resposta
Sande Jarrett será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 5,872
