Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Perguntas Visualizar todos
How can I get click wheel to respond. iPod 5th gen
I checked this site and found others had a similar problem so I followed the recommended solution. I ordered a new click wheel from ifixit and replaced it. No luck. Still have the same problem. The replacement wheel did not solve the problem. What are next steps?
Thanks
Esta é uma boa pergunta?
Pontuação 1
3 comentários
What problem are you having?
por
Matt, My iPod comes on when I switch the lock key, the screen lights up, I see Menu, Photos, Videos,...but there is no response when I click any of the buttons on the click wheel. Nothing happens and the screen goes to sleep. Could it be a battery issue? It shows it is fully charged.
por
Hi Did anyone find a solution to this problem
por
Adicionar um comentário
6 respostas
Solução escolhida
randyhondros, try to turn hold on and off and then press the center button and menu at the same time, this will reset it. Can you get to the diagnostics menu by turn off the “hold switch”
  1. Press and hold “Menu” and “Select” buttons simultaneously for 10 seconds to reset the iPod.
  2. The Apple logo will appear and you should feel the hard drive spinning up. Press and hold both the “Back” and “Select” buttons at the same time.
  3. The Apple logo should appear backwards. Let go of the “Back” and “Select” buttons. You should now be in diagnostic mode.
If you check this link, http://www.methodshop.com/gadgets/ipodsu... it tells you about the test you can perform, there is also one for the click wheel.
Of course if your click wheel is not working at all you will not get there. Make sure that all the connections on your logic board are seated snug and that all connections are clean and free of any debris or corrosion. If none of these does not work, I think you may be do for a new logic board. Good Luck and let us know how it is going.
Esta resposta foi útil?
Pontuação 5
6 comentários:
Oldturkey03, I Have tried pressing Menu and Select but nothing happens. Tried it both before and after replacement of the click wheel. Same results no response. I have checked to make sure all connections are seated snugly. Do you think it is worth investing in a new logic board?
Thanks!
por
Honestly, yes I do. I enjoy the Ipod video and found that by keeping it alive I actually save money. I purchase my logic boards at different places, iFixit has them here http://www.ifixit.com/iPod-Parts/iPod-Vi... and they are frequently on ebay. I find that I could not buy anything like the iPod video for that price. Hope that helps and wishing you and your ipod all the best.
por
Olturkey03, thanks for the feedback. I have ordered a new logis board. With a new logic board and new click wheel, I would expect this will fix my problem.
Thanks!
por
I am certain it will, you just let us know when you have it and let us know how it turned out. Hope to have you jamming soon....:)
por
going the extra mile here turkey.. you are a gentleman!
por
Exibir mais 1 comentário
Hi all my daughter has just returned from a year in OZ and asked me to look at her 5th generation Ipod as it was not working. I am a pretty dab hand at taking things apart and trawling around for answers. Well once you get the hang of opening one opf these babies it is not that difficult connecting and re connecting the parts. The first thing that I noticed was that there was half a pound of sand in the darn thing so no wonder it was not working. I cleaned it all up let it dry out then re-assembled the unit but found the click wheel was dead. The majority of info on the web was about restoring the ipod but if the click wheel will not respond at all then that information is pretty useless so I bought a new click wheel on Ebay and I also bought another faulty 5th generation IPOD that was sold as faulty and did not work. Once it arrived I got to work on the Ebay item took it apart and fitted the new click wheel but it did not function. I cleaned out my daughters Ipod completely fixed the new click wheel into this and again nothing. So what I had now was two faulty ipods and about £25.00 out of pocket that is until I found this method on the web and I had nothing to lose.
This is going to sound pretty wierd I know but I again took apart the two Ipods removing all the connections (I was quite an expert by now) and the part that I wanted to work on was the main board the one with all the bits on that everything connect to. With everything disconnected I did this..
Using cold water and a soft tooth brush I cleaned both sides rubbing gently and I then dried this with a hair dryer but be careful not to be too agressive withn the heat. Now this is even crazier I know but I cleaned it again using Vodka, yes Vodka and a tooth brush. The original poster actually said alcohol but it's the closest I had and thought what the heck. Once both sides had been cleaned with the vodka I let it dry thoroughly re-assembled and hey presto as if by magic it was fully functioning. Well i wondered if this was coincidence, you know I may have dislodged something or re-connected something just by the action of taking it apart and putting it back together so I tried it on my daughter non functioning Ipod and had exactly the same response. So we need to two fully functioining IPODS. My wife thought that I was going a bit mad but afterall I once fixed the tumble dryer for £1.00!
I am not suggesting for one minute that upon reading this that you take your Ipods apart and ply them with alcohol but if you are like me and have a non functioing Ipod that is only fit for a faulty unit on
Ebay and you like the fun & excitement of a challenge then why not.
Pontuação 1
1 comentário:
sean parker, nothing weird about it :-) well the Vodka thing might just be a bit over the top :-) What you did was the right thing. We do have a guide on here that deals with cleaning any kind of electronic device. I do know that in this particular case, it was a tore click wheel cable, but you are right. Sometimes just by disconnecting and reconnecting, we can eliminate improperly seated components. Good job and thanks for sharing.
por
Sounds like you have a bad click wheel. I would replace that first and see if it fixes the problem.
Pontuação 0
16 comentários:
I thought it was already changed with a new one from ifixit. I really need to get me some glasses :-)
por
Old turkey...no need for glasses. I have already chnaged the click wheel and have ordered a new logic board as you recommended.
Thanks
por
Old turkey or Anyone...need help! Replaced the Click wheel and now the logic board. I still have the exact same problem. The screen lights up when you slide the hold button to the left, I see Music, Photos, Video, etc. After a few seconds the screen goes into sleep mode (gets darker but I can still see the menu list). No response from the click wheel. Cannot reboot. After a couple of minutes the screen goes completely dark and I have to slide the hold key to the right and then back to the left to get it to light up again. Any thoughts? Anyone?
por
randyhondros don't give up yet and don't get frustrated :-) I know how it goes trying to look through my notes to see if I have a solution somewhere. Thanks for the very precise description in your comment this will help to narrow it down. we'll gt it working I have a couple 5th gen right in front of me and see if I can create this error and see what can cause this oddity....
por
Okay so I tried to reproduce the error and the only thing that comes close to what you have is when I use a bad hold switch. It turns on gets to the menu but keeps the click wheel from responding. The back light turns on when I move the hold switch but turns of at the preset interval and thus maintains the menu of the screen but with the light off. I know that you said that the lock shows on your screen but I think the lock symbol and the actual hold function are separate circuits and does not necessarily verify that it is functioning and may just be a red herring in this case.Do you have a hold switch that you can replace to test it out.I am sure that you have it all put together right, but double check that the ground of the click wheel is connected to the frame. I have a few here with older back plates if you need some, let me know.
por
Exibir mais 11 comentários
Now 2020, I still think it is a hold switch problem, anyone came with a solution about this?
Pontuação 0
1 comentário:
I've got the same issue, and about to try replacing the hold switch next. Did that work for you?
por
Did anybody try sliding the lock switch back and forth very rapidly, several times (at least 10-20 times) in a row? I read that somewhere a long time ago and that helped my locked up fifth gen working again.
Pontuação 0
Not sure if this helps but I've been having a similar clickwheel problem. Mine does not function at all. I'm about to recheck again all ZIF connectors for misalignment and after reading some posts here particularly oldturkey's.
I suspect he is " on the money" in looking at the hold switch. It may not be the switch itself but perhaps a ribbon cable leading from it.
If anyone has replaced their battery in the course of their repair or mod they could have easily damaged or simply unseated the square shaped earth or ground that is just glued to the back casing and also given help by the battery being glued to the backcase. Puttingextra pressure on that small square tab. The ground or earth tab lays under the stock OEM Battery and is pressed into position or held in place by the battery.
Because in my own mod which included an iflash quad and a new stonking great big battery which no longer aids in pressuring that ground/earth tab. After the clues given by mainly oldturkey but others too I found that ground tab was not adhered as well as it could be to the back case. So I supect that could be at least part of the cause.
I'm about to recheck all those connectors and the clickwheel earth/ground itself. If it works and I'm triumphant I'll let you know...if it's a red herring I'll quietly hide with my tail between my legs.
Oh I thought about using scotch instead of vodka as that's what is at hand...didn't because I feared all the ipod might be good for after that was Bagpipe Music!
Cheers,Andy
Pontuação 0
Adicionar a sua resposta
randyhondros será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 62
Duração total: 14,047
