Ir para o conteúdo principal
No backlight after unlock phone (backlight work during boot)
Hi guys,
recently i repaired iPhone 6 water damaged.
I replaced PMIC, after then phone boot but there are not backlight and touch. I replaced:
- backlight IC
- backlight capacitors
- touch ICs - MESON, CUMULUS
- LCD IC - CHESTNUT
Now after press power button, phone boot with backlight and work normal. When i lock phone, LCD goes off, but when i want unlock phone there are not backlight. Touch and LCD work.
My question is:
Where can be problem? It look, backlight driver do not receive ENABLE signal after booting and do not want work.
Can be here problem with
45_AP_TO_PMU_AND_BL_DWI_CLK
45_AP_TO_PMU_AND_BL_DWI_DO
For what is there this bus?
Sorry for my bad english :)
Thanks
@refectio
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Those two lines are part of the I2C bus. You will want to check them to insure they are not shorted. I would also look at pin B1 of U1502. That is the Hardware Enable pin. I don't know enough about the internal logic of these IC's to say what could be causing this.
Esta resposta foi útil?
Pontuação 2
I fixed so many backlights specially on 6 and 6s. Normally it's filter
But recently I d given iPhone 6s with very low backlight
Checked all caps, filter, diod, coil etc. Everything seemed fine so I changed backlight ic(u2040) no luck
And than I changed main pm ic and problem has gone.
Pontuação 1
2 comentários:
How do you know that you must replace PMIC? Should i use multimeter?
por
yes check all the voltage and most importantly recistance of the components.
But you said you have changed it didn't you?
But again your phone is the water damage. Could be anything man.
Have you checked any short?
por
Adicionar a sua resposta
Tomas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 476
