Ir para o conteúdo principal
Uma câmera digital point-and-shoot de 95,2 mm por 56,5 mm por 18,3 mm lançada em março de 2012.
file error message pop up
Why does a file error message pop up when looking through pictures I have taken instead of a picture that I took, but is no longer on camera? instead it says file error with a triangle.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@froggman from the manual:
The following issue can cause a File Error message:
  • The picture file is corrupted
  • The picture was taken with a different manufacturer's camerahe memory card inside your camera is not formatted
  • The memory card in the camera is not compatible or defective and needs to be repalced.
I'd start with formatting the card and see if that works. If not replace it with a new one. you can get the user manual from here which tells you how to format the card etc.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Justin Hoelscher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 42
Ao todo: 1,181
