Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Xbox One S. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Xbox One S.
Help with stuck Xbox Controller B button
So, I have a Xbox One S controller with a stuck B button. I called Microsoft and they are sending me a new one and letting me keep the old one. So, I was wondering if I could fix the messed up button. It registers as pressed constantly but is not physically stuck. Has been tested on 2 Xbox Ones and a PC.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
You can try this teardown below and see is something is possibly jamming the B button under the rubber as shown in step 8. It might be a software issue as well, but it's worth a shot to take it apart if it's not working anyways.
Xbox One Wireless Controller Teardown
Esta resposta foi útil?
Pontuação 4
4 comentários:
Thanks! I’ll try this. It’ll have to go on my teardown table tomorrow!
por
This worked! The button was caught somehow on the paneling. I broke the haptic motor doing it but I have a soldering gun...
por
Ayyy, good to hear. Glad you figured it out and good luck with the re-soldering
por
I don't know how to solder I have a brand new well two-week-old Xbox One controller and the a button is sticking it's not dirt and I don't know how to solder I also don't take apart controllers I don't have that level of high-tech is there help please I need to fix my controller and I'm kind of limited Q-tips and alcohol fix dirt it's not dirt
por
Rubbing alcohol on a q tip wipe around edge of button and press the button rapidly no more sticky button your welcome
Pontuação 0
1 comentário:
As I said, it is not physically stuck, I don’t eat and game. It’s something within the device, it clicks just fine.
por
Adicionar a sua resposta
Reed Crosby será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 88
Ao todo: 53,997
