Ir para o conteúdo principal
Nikon Coolpix L18, 8.0 Megapixels, 3x optical zoom, 3.0 inch LCD
4 Perguntas Visualizar todos
lens will not extract or retract
Lens on Nikon Coolpix L18 will not extract or retract. I hear the motor running but no movement of lens. Lens cover does work when gears are manipulated by hand. I have the camera disassembled and need some guidance to open correct part of the lens housing to fix mechanics of its movements.
I thank you in advance for your advice.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
sarkis did you manage to fix this problem? if oldturkey's solution has helped would you please come back and accept his answer? thankyou
por
Adicionar um comentário
2 respostas
Solução escolhida
Sarkis Paronyan, I do have the complete repair manual and parts list for your camera. Do feel free to download it, it comes in 4 parts that you have to have and the parts list. That manual will tell and show you all you ever wanted to know about your camera. :)
Manual and here is the partslist
Good luck to you and your camera and let us know how it went.
Esta resposta foi útil?
Pontuação 3
10 comentários:
oldturkey would you have the guide for the Nikon Coolpix L1 ?
por
thanks and sorry for hijacking your answer :-)
por
Hello oldturkey03,
Thanks for answering my question however I am late in retrieving these files and they are already removed and I am unable to download them.
If you do not mind replace them and I will download them.
Once again thank you very much for your response and provided information.
Sincerely,
Sarkis Paronyan
por
The manual is now available at Manual and here is the partslist Good Luck.
por
Hi oldturkey! Can you please upload the manuals again?
Thanks!
por
Exibir mais 5 comentários
Hey oldturkey03 Are you still around? I have come to need the Nikon CoolPix L18 Manual & PartsList, would you please send it my way at christiangrivas@gmail.com
Thank You Very Much
Pontuação 0
Adicionar a sua resposta
Sarkis Paronyan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 4,605
