Ir para o conteúdo principal
O Twentieth Anniversary Macintosh foi um computador pessoal de edição limitada produzido pela Apple Computer, Inc., em 1997, em comemoração ao 20º aniversário da empresa
Screen replacement on a TAM
Greetings.
Is there a guide available to replace the screen on a TAM?
Thank you for any information.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Surprisingly the one guide we have will get you there!
Here is the guide: Twentieth Anniversary Mac Teardown. Follow it thought to Step9 to get the front off which has the LCD screen mounted.
Just be careful you get the correct replacement display, you can't substitute.
Esta resposta foi útil?
Pontuação 3
7 comentários:
Just to confirm, please: ALL steps through step 9 are required? (Thank you for your response.)
por Compartilhar
We just don't have a proper guide, yes I'm sure a few of the steps could be bypassed. As you go thru the task how about creating a guide ;-}
por Compartilhar
Hang on to this machine, it's one of the few older ones that retain real collector value. I think there were only 10 or 12,000 of them made. I only know of one in my town.
por Compartilhar
Agreed! Its a collectable.
por Compartilhar
Thanks, guys. Yes, I intend to keep it. It is iconic ... in its own rather eccentric way. (I'll try to complete a guide; however, I think I would end up plagiarizing most of Dan’s guide. If I’m successful, I will be sure to note proper attribution.)
por Compartilhar
Exibir mais 2 comentários
Adicionar a sua resposta
Michael será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 1,146
