Ir para o conteúdo principal
replace screen in ON mode, but display not shown.
Hello All,
I replace display of my I phone 6 with new one but still black screen shows. I try all idea like hold Sleep/wake botton with home botton, but problem not solve yet. Can any one help me about this. I connect display in ON Mode, is this occurs this problem.
if yes, then please hint to solve this.
Regards
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If you connect your phone to an iTunes enabled computer, does iTunes recognize that your phone is connected?
If you shine a bright flashlight on the screen when it is supposed to be on, can you see a very dim/dark image?
If it is, then you likely have a bad replacement screen or you have a problem with the LCD or Backlight driver circuits. Please get back to me with the answers to my questions (leave a comment).
Esta resposta foi útil?
Pontuação 2
2 comentários:
I have the same issue can you respond back ? My iPhone 6 turns on but there is no apple logo and very dim lighting , please help .
por
Hi @kianas0910, you should create your own question as each situation is different, even if they appear similar. You can tag me in the question using my username (@refectio) if you'd like.
por
Adicionar a sua resposta
dinesh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 48
